Oil Pressure fluctuating and SES (EGR problem)
Old Apr 26, 2011 | 07:18 PM
Catmaigne's Avatar
Exclamation Oil Pressure fluctuating and SES (EGR problem)
The oil pressure gauge fluctuates quite a bit on my 96 Z28. See for yourself as I rev to 3,000:
YouTube - VIDEO0008
Is this normal for an 80,000 mile car that just had a recent oil change? I was wondering if this is a problem with my PCV valve or if it could be somehow linked to another reoccurring problem I've been having. I used an OBD2 diagnostic tool to uncover why my service light came on roughly 2 weeks ago and found 2 DTCs:
- P1657 aka Skip Shift unplugged (no worries, did that last week after 10 trips to the gas station so now I can shift when I please)
- P0400 aka Exhaust Gas Recirculation Flow
I'd assume there's something wrong with my EGR valve or something in the EGR system, but I was wondering if there is any correlation between my sharp oil pressure increases and this DTC. The CAT and O2 monitors on the diagnostic tool refuse to complete their tests, but I can tell the car is running rich judging by the potent smell of gasoline, the crap mileage, and the popping from my exhaust upon decelerating (you can hear it in the video when I take off the throttle if you listen closely). Is there any common factor to all of these problems?
Any suggestions of how to go about fixing these problems?
Old Apr 27, 2011 | 08:19 AM
no egr should not have an effect on the oil pressure readout.pressure flux is not unusuall. a tad low on idle, what wt of oil are you using? may want to switch to a little heavier.
Old Apr 27, 2011 | 10:14 AM
Catmaigne's Avatar
The car is filled with a quart of Royal Purple 5W30 and the rest topped off with Mobil-1 of the same weight. I also changed the oil filter to a Fram PH30 if that's at all relevant.
Old Apr 27, 2011 | 10:16 AM
i would get rid of the fram filter. next time you change oil try 10w30. should bring you pressure up a tad.
Old Apr 27, 2011 | 11:21 AM
BasicConcepts's Avatar
Technical User
my v6 would move about that much on a fresh oil change but i always put 10w30 in
RedSled99
Apr 17, 2013 01:42 PM
grasshopper645
Jan 27, 2013 03:08 PM
Speedfreak02
Jul 13, 2012 02:28 PM
MegametedK
Nov 16, 2009 12:17 PM
meniscus
Apr 6, 2008 12:49 AM
