Oil light & fuel problem 98 camaro
The oil light that comes on is low oil...checked oil pressure it is fine and checked low oil and it is also fine...not sure what this is....so in the mist of all this with the oil problem...now I have a fuel problem...nice huh...looks like my fuel pump is on it's way out...I was driving and almost lost total power so pulled over check engine light flashing on and off....waited a few then drove home...ran tests and it burn out coils 3 & 6...replaced those and it was ok for about 15 minutes...drove around for a little while and when I go to pull in the driveway I hear a squealing sound coming from the back of the car...almost like a distant tornado siren...once again she looses power and now sounds like a big piece of poop...also has a very rich smell of gas...any info is greatly apperciated thanks
check your fuel pressure. a failing fuel pump will sometimes be noisy. have you changed the fuel filter? be a good first action. the oil level sensor is on the driver side of the oil pan. check wiring to it for any damage. if none change sensor.
evilbeef54
07-27-2008 09:47 PM
