Oil Leak Need help
Old Sep 7, 2021 | 07:10 AM
Blackrag's Avatar
Default Oil Leak Need help
Hello to all- Just picked up my "new" 1994 Z-28 Convertible. Got it home and noticed an oil leak and traced it to the front main bearing seal. Have several questions. What should a guy pay to have the seal replaced. I heard its a booger of a job and takes a good mechanic who knows what "Torque and angle" means. What if I just say the heck with it and put in some of that seal conditioner. Does that stuff work and will it cause more problems ? Also it has 125K miles on it and looks like the plugs have never been changed. One fellow told me not to worry about it if it runs OK. Suggestions ? One more thing; So disappointed to see it has a 115MPH speedo. Please tell me all the issues with putting a 150 MPH speedo. Does that mean I have a speed limiter ? (It has 235 tires). Thanks
Old Sep 8, 2021 | 05:23 AM
if you got the right tools changing front seal is not a big thing. pull balancer and balancer hub, pull an replace seal and put balancer back on.
Old Sep 8, 2021 | 05:26 AM
change the plugs,,, its worth it,,, might take all day,,, or two,,, lol. again having the right tools can make it much easier. flex head 3/8 ratchet helps. I usually take my time so I don't get frustrated so it can take most of a day but have done it in a couple hours.
Old Sep 8, 2021 | 06:41 AM
Blackrag's Avatar
Thanks graby Can always count on you with good advice. Pls give me input on the seal conditioner and the 150 mph speddo. thanks
Old Sep 8, 2021 | 08:05 PM
Seal conditioner is a long shot,might buy some time might not,I'd do it right and forget about it.
If memory serves that speedo is a convertible thing,not sure what it takes to swap in a 150,thinking there's a speed governor on the ragtops so it's probably tied into the ECM.
B_Dubya
Nov 14, 2018 02:14 PM
Reverend
Oct 29, 2018 10:31 PM
adam.howard450
Jun 18, 2013 09:50 AM
94ttop
Aug 13, 2009 08:23 PM
4speed
Apr 26, 2009 12:27 PM
