Oil Change time, would like some thoughts
Old Apr 25, 2012 | 05:48 PM
  #21
torque_is_good's Avatar
Originally Posted by DashingDaryl
Did you know the owner's manual for a C5 Corvette recommends an oil change every 7,500 miles using Mobile 1 5w-30?
A BMW Z4 has an oil change interval of every 12,000 miles using a Synthetic European formula Castrol blend.
Since these folks are worried about engine reliability and not selling motor oil, I tend to think that an oil change every 3000 miles may be a marketing thing. I also think it proves that a high quality oil filter can last that long also.
hour meters should be standard equipment in every vehicle.
Old Apr 25, 2012 | 08:09 PM
  #22
androzer's Avatar
so?
I want straight answer LOL cause I cant solve out riddles in English :-D
well I can but I dont wana take risk of understanding and then say Ouch, motor wrecked because of mistranslation.
I drive my car only 5000 KM per year , can I put oil last for 12000 Km and not change it for 2 years?
Old Apr 25, 2012 | 11:25 PM
  #23
Z28Camaro98's Avatar
My LS1 has 198,800 miles on it. Ever since 40,000 miles, it has been run on Mobil 1 synthetic 5w30 changed every 3-5k miles. My oil pressure as idle, when hot is 40 psi. pretty amazing if you ask me.
Old Apr 26, 2012 | 12:18 AM
  #24
that is pretty good pressure. i try to keep an eye on the condition of the oil using... my eyes. lol. and yes the crabber is my boat used for fishing crab
Old Apr 26, 2012 | 07:23 AM
  #25
Originally Posted by androzer
so?
you probably have not received a reply because you hijacked the thread
what do the 5km driven miles consist of? Do you drive 1000 km 5 times per year. Do you take short hops several times per week? Short hops where the engine never get's fully warm are not good either.
Old Apr 26, 2012 | 08:24 AM
  #26
androzer's Avatar
yes 1000 KM * 5 = 5000 KM per year.
yes short hops after warming the car for 4 minutes before driving.
can I put oil last for 20 000 Km and not change it for 4 years or 2 years?
Old Apr 26, 2012 | 10:05 AM
  #27
honestly, with an engine sitting idle for extended periods you'll want synthetic but you will still have dry cranks. I would fog my outboard engine when I had one and it sat for extended periods of time.
I'd hate to say this but you are claiming around 3k miles per year so that would fall under "severe" conditions
I question your 3k miles per year unless it's a show car but we're all anonymous here
Old Apr 26, 2012 | 10:40 AM
  #28
Every engine has a certain amount of ring blow-by that puts combustion gases in the oil. Short trip driving (even after a warm up) can cause the crankcase to accumulate moisture. These can make the oil more acidic, and you don't want your engine's innards, primarily the bearings, "soaking" in that oil for years on end. That's why oil change interval suggestions are X amount of miles, or X amount of months, whichever comes first. If your car gets parked for the winter, change the oil right before you put it in storage.
Old Apr 26, 2012 | 11:37 AM
  #29
also, once you pick an oil, STICK with it. if you go synthetic, keep using it not back and forth.
Old Apr 26, 2012 | 04:22 PM
  #30
DashingDaryl's Avatar
Well, that is a good reminder for me to not assume anything. I would not have guessed you were a Deadliest Catch guy. Since you know so much about our cars, I always assumed you were a professional mechanic of some sort.
I have to say, I REALLY APPRECIATE ALL YOUR ADVICE, it has helped me out a lot.
