OBD1 Pin Jumping
Old Jul 5, 2013 | 07:39 AM
JaredSmith's Avatar
Default OBD1 Pin Jumping
Hey guys, I have an intermittent code on my 94 z28 that keeps popping up about once a week. I just tried to jump the pins but it wont go into diagnostic mode, I should also note that I have the low coolant light now and then as well. Has anybody else had luck jumping the two top right pins in the obd1 connector? It would be a very convienient way to pull codes without buying a scanner. Does the code has to be active in order for it to go into diagnostic mode? or should I be able to read stored codes anytime?
Old Jul 5, 2013 | 07:48 AM
you can not flash for the codes on a 94. 93 was the last year.
Old Jul 5, 2013 | 08:25 AM
JaredSmith's Avatar
Can you reccomend a good scanner for 94s? I tried one at Partsource and it wouldnt respond, I would like to get this code cleared up, I dont think its anything serious because the car has been running great but I hate looking at this ses light
Old Jul 5, 2013 | 09:07 AM
Old Jul 6, 2013 | 03:54 AM
mfmfim's Avatar
I have a 94 K2500 and a 98 V6 Camaro and I wanted a code reader that would work on both cars. I purchased the Innova 3120b and I'm very happy with it. It cost from $142 to $200.
It reads OBDI and OBDII.
Vet76te
Jul 14, 2010 11:54 PM
OttoMan
82-92 V6 Tech
Nov 25, 2009 05:29 PM
