O2 sensor fuse?
Old Apr 17, 2011 | 02:50 PM
Bzman's Avatar
Default O2 sensor fuse?
Hi, I have a 99' camaro v6 throwing a P0147 code (O2 sensor bank 1, sensor 3). Before replacing the O2 sensor, I was told to check the fuse first. Looking in the GM car manual, I didn't see O2 sensor in any of the fuse descriptions. Does any1 know which fuse this would be? Thanks.
Also, any1 know a good place to buy this O2 sensor, if needed? I've seen them in the $60-$70 range on various websites.
Old Apr 17, 2011 | 04:12 PM
The heater portion of the O2 sensor is fused, but only has power with the key in the ON position. The fuse is usually labeled "FANS/ACTR" or similar. No need to remove fuse as long as thee key is turned OFF.
izayuhgawd
Nov 21, 2011 09:24 PM
fuhhuayt
May 5, 2011 01:04 PM
EagleRex
Jul 20, 2010 03:36 PM
masonhoban
May 8, 2010 05:57 PM
ladybridgeport
Apr 5, 2010 08:44 PM
