Not starting
Old Nov 14, 2021 | 11:35 AM
GNGAL's Avatar
Default Not starting
Need help pls… car not starting.
I have power to ignition wires, coil pack at 5.03 volts, but Noid light doesn’t light up. —- NEED HELP PLEASE
1994 Camaro 3.4 V6
Old Nov 14, 2021 | 02:55 PM
is the security light staying on or blinking/? have a look at this an see if anything helps https://camaroforums.com/forum/93-02...18/#post618955
Old Nov 14, 2021 | 03:00 PM
if you haven't you can go here and download the complete manual for your year. 1994svcman https://www.mediafire.com/?40mfgeoe4ctti
Old Nov 14, 2021 | 05:42 PM
cwilt's Avatar
Do you hear the fuel pump turning on then off when you turn the ignition key? Are you getting spark at the plugs?
Old Dec 1, 2021 | 07:06 AM
Corey Jordan's Avatar
I had a problem where it would turn over and die immediately, sometimes just turns over without starting. It was the engine wiring harness. Some of the wire insulation broke and started rubbing.
Also, mentioned earlier, is the fuel pump. If you can't hear it prime, carefully let out the fuel and pressure at the rail service port. Turn the car to ON a few times then check the rail. No fuel is a bad pump or severely clogged filter
Air+Fuel+Spark= Running Engine
Sounds like you might not have spark. Without any codes or, like before, a SECURITY light on or flashing, there isn't much else i can think of... Neutral safety switch maybe?
Old Dec 10, 2021 | 11:45 PM
loading......'s Avatar
I have a 3.4l v6 currently I have a vats problem, my key won't work, and the security light also doesn't work. but before that happened i had my injector fuses go out, the stupid thing is that they didn't look blown, so I spent over $1000 throwing parts at it. And what fixed it was pretty much free.
-check your ignition fuses
*Just place a fuse there from somewhere else
-fuel pump / and relay
*the relay is behind the interior panel footrest by the brakes
-Vats system
*Under the steering column should be the orange wire (NOT THE YELLOW WIRE!!)
-fusible links ***
*Located by the battery, the red junction box
dl4jesus
May 18, 2021 09:22 PM
zdadzdad
Oct 25, 2017 08:26 PM
fatoeknee
Mar 16, 2008 02:49 PM
camarocraz
Feb 19, 2007 12:21 AM
Dj Fo Real
Dec 30, 2006 03:43 AM
