Nose Emblem Removal
Old Nov 28, 2007 | 01:47 PM
MassholeLT1's Avatar
Default Nose Emblem Removal
I want to replace the Chevy emblem on the nose of the Camaro- the red white and blue one. How should I go about removal of the old emblem?
Old Nov 28, 2007 | 03:02 PM
Chappie99's Avatar
Default RE: Nose Emblem Removal
heat gun on low indirect heat. If you allow the heat to stay on the paint, you may damage the finish. Try holding a heat gun (in the on/low heat possition) about a foot or so from the emblem, after a few, it should heat up and come off with a little help. Or you can try and just peal it off.
Old Nov 28, 2007 | 03:16 PM
Thanks for the reply Chappie. I dont have much experience with using a heat gun and I dont want to bubble my paint.....I might just heat it up a bit with the hair dryer then pry it off? Is it just stuck on with adhesive?
Old Nov 28, 2007 | 10:00 PM
Redneck97's Avatar
yes i belive it its you should be able to pill it off. I would think so at least.
btw what are you replaceing it with?
Old Dec 1, 2007 | 10:06 AM
SomeCallMeFonzi's Avatar
on my 3rd gen that i had it actually had little pegs in it that went into the nose to hold it in but im not sure if thats how it is with the 4th gens
Old Dec 1, 2007 | 10:42 AM
How did you remove it with the pegs?
Old Dec 1, 2007 | 12:31 PM
Chappie99's Avatar
its just a sticker, peel it off. Found one @ a bone yard and I just peeled it off.
Old Dec 1, 2007 | 01:42 PM
You think my paint will come with it?
Old Dec 6, 2007 | 10:57 AM
ORIGINAL: Redneck97
DONE!
Old Dec 6, 2007 | 01:27 PM
Blade's Avatar
June 2007 ROTM
hair dryer and then goo gone for the glue
