No start - Relay Location
Old Aug 1, 2007 | 03:06 PM
tofudi's Avatar
Default No start - Relay Location
I've checked and replaced both starter and batery.
Checked Clutch Safty Switch.
Checked Ignition Switch.
Fusable Link.
Only thing else on my mind is the damn Theft Deterrant Relay. It isn't witht he rest of them, it must be hidden somewhere to prevent people from and easy steal.
Anyone know where it is?
Old Aug 1, 2007 | 03:26 PM
evilhaserrors's Avatar
Default RE: No start - Relay Location
Hahaha, been there, done that. what happens when you turn the key? flashes check engine light? What year/car do you have? Might have had the same problem I had with my 94' last week...hope you know how to solder!!
https://camaroforums.com/m_97384/tm.htm
Old Aug 1, 2007 | 03:59 PM
tofudi's Avatar
97 Z28 6spd.
I get Service Engine Soon, ABS INOP, Check Gages, Security, and maybe something else.
I disconnected the wires from the ignition switch and crossed the red and yellow wires which should have activated the starter. Crossing to the pink activated the radio and dash lights. That tells me the switch is alright, the problem is further down the line.
Before I replaced the Starter, crossing the soleniod DID NOTHING. We pushed it and popped the clutch and it started for two seconds. Crossing the NEW starter, it will now start for two seconds, then die.
Otherwise - no activity.
1augapfel
Oct 23, 2012 12:29 PM
sewerrat
Jun 24, 2006 05:51 AM
Robby93
Jun 19, 2006 10:05 PM
