No spark from coil
Old Aug 27, 2025 | 05:25 PM
Blackrag's Avatar
Default No spark from coil
Well this is getting pretty frustrating. Still cant get the 1994 Z-28 to fire. I replaced the Coil and the ICM this morning. I tested the ICM harness yesterday and all pins A,B,C, ad D checked OK. Thought for sure then that the Opti was putting out OK and it must be the ICM that was the problem. New ICM, same problem. Checked the coil while cranking the car and have NO output from the coil. How do check the coil harness for input to the coil. (It's a double clip harness with two pins in the top plug and one pin in the bottom plug). I'm I back to thinking it's the Opti that is the problem, in other words does the coil receive any signals from the OPTI to make it fire ? Please help.
Old Aug 28, 2025 | 04:13 AM
Robroy Z28's Avatar
Did you check if it throws any codes?
https://petrisenterprises.com/blogs/...roubleshooting
Old Aug 28, 2025 | 08:44 AM
opti test, 4th Gen LT1 F-body Tech Articles
the factory manual has a cranks but will not start trouble tree. this is what my 93 book shows, https://camaroforums.com/forum/lt1-l...37/#post579761
Old Sep 8, 2025 | 06:35 AM
Blackrag's Avatar
Not yet. Found out the A-B pin jumper with a paper clip trick to look for flash codes, does not work on 1994 vehicles- go figure. I bought a jumper wire converter, OBD 1 to OBD2, but I dont have the right OBD 2 scanner with a batttery in it to provide power- ug
Old Sep 8, 2025 | 08:48 AM
Terry
Jul 21, 2018 09:53 AM
camarorz28
Aug 16, 2008 12:13 AM
joeyninetoes
Nov 28, 2007 09:07 AM
Smoo
LS Series Tech
Jun 10, 2006 01:00 AM
