New wheels today
Old Dec 25, 2011 | 09:56 PM
1slowv6's Avatar
Default New wheels today
Hey guys i got a set of C6 ZO6 wheels today so i put them on obviously.
the wheel/tire combo dropped the car about 3/4" - 1" so thats all good but now i would like to complete the look and get some lowering springs.
ive pretty much decided on the eibach pro kit springs. and would like to know what supporting mods i will need so i dont ruin any suspension components on down the road from being low
heres a pic of the wheels. it was dark when i put them on so i dont have a picture of them on the car yet but it looks good
Old Dec 26, 2011 | 12:32 PM
vanquishfist's Avatar
Strano springs are about the same price and much better quality. Eibach springs are known to sag (esp the pro-kit). Ideally you need adjustable shocks like Koni when running lowering springs. You can get away with using Bilsteins but they won't last as long.
I recommend doing your homework before lowering your car. Calling Sam Strano would be a good place to start.
Old Dec 26, 2011 | 05:23 PM
1slowv6's Avatar
[QUOTE=vanquishfist;596454]Strano springs are about the same price and much better quality. Eibach springs are known to sag (esp the pro-kit). Ideally you need adjustable shocks like Koni when running lowering springs. You can get away with using Bilsteins but they won't last as long.
I recommend doing your homework before lowering your car. Calling Sam Strano would be a good place to start.[/]
I've lowered cars before but every car has different weak spots. I'm trying to see what problems people have had with the f-bodies.
I am just new to the camaro so I didn't know about Strano springs, thanks
Old Dec 27, 2011 | 08:47 AM
torque_is_good's Avatar
ehem............
how did replacing wheels lower the car?
if you sized them wrong and the car's height did drop 1 inch then your speedometer is now way off and your "gear ratio" has changed
let's get back to basics
xxx by xxx by xxxx were previously on the car
xxx by xxx by xxx are now on the car
oh, the z06's are on my 4th gen (black) and i love the look
Old Dec 28, 2011 | 12:45 PM
libertyforall1776's Avatar
Pretty much what Vanquishfist said, and I have been saying to others on this board. Leverage Strano's experience and save yourself headaches later!
Old Dec 29, 2011 | 04:27 AM
flowride's Avatar
I lowered my car with Eibachs while using KYB shocks, 18" rims and tires. Back end would bottom out over SLIGHT BUMPS. I ended up leaving it lowered up front and put the stock springs back in the rear. At some point, I'd like to go up to 19's or 20's in the back with wheels/tires and go one inch smaller up front. It's all about money and every time I have it, the fiance has something she wants to do to the house. Grrr...
Old Dec 29, 2011 | 09:00 AM
Originally Posted by torque_is_good
ehem............
Wasn't just the wheels:
Originally Posted by 1slowv6
the wheel/tire combo dropped the car about 3/4" - 1"...
To drop that amount, that would mean the new tires are 1.5"-2" lower in overall height than the old tires were. Are they that much smaller? You can look up the tire specs on tirerack.com. And yes that will throw your speedo off, registering faster than the car is actually going. On the plus side, smaller diameter tires will give the car better bottom-end.
Old Dec 29, 2011 | 09:59 AM
he still hasn't responded to my request for before and after tire dimensions
I mess with going wider all the time and try to keep within 1/8 inch height difference at most.
My favorite are the Chevy Impalas I see rolling on what looks like 3-4 foot tall tires
Old Jan 6, 2012 | 01:39 PM
1slowv6's Avatar
Ok sorry about not getting back I thought the thread died... Anyways i don't know the old tire combo but I believe it was stock size. The new tires are 275/40/17's the speedo isn't off at all because it's such a subtle difference in tire height. Has anyone on here used ground control to lower their car an what do you think because that's what I'm leaning towards
Old Jan 6, 2012 | 09:12 PM
vwmercer98's Avatar
if h and r makes a kit for these i owuld go with them. they are always good quality. they are the brand to go with in the vw world
MaVeN
Aug 22, 2010 12:21 PM
Attila
Oct 3, 2007 07:42 AM
