New battery needed?
At night when i want to start my car and i have my car key turned into "on" (without the engine running) the dashboard light are dull and not bright when I finaly start the car the lights slowly get brighter and brighter both on the dashboard as well as my headlight (I have HID lights installed). What might be causing this problem? Is it the battery I can't tell how old the battery itself is because the sticker on it is gone.
Could be the battery. Stop by your local autozone or advanced auto and they can test it and let you know. Sounds like maybe a dead cell. Also, check the battery cable terminals to make sure they are clean and tight as well as the ground on the inner fender on the passenger side. I don't think it would be the alt because with the lights getting brighter, that means the battery is charging.
Ok so i went to autozone and i got both my alternator as well as my battery checked the guy said that my battery is nearly new and my alternator is checkingbout good but he said it will propobly go out within a year what else might be causing this and should i replace the alternator?
kinda sounds like the problem I had, come to find out I had a bad alternator from the start, I had autozone test the alternator and it always came out good but it was bad, replaced the alternator, and that was bad, exchanged it and fixed my problem.
An Alternator that is checking out can take a good battery with it. If you suspect it to be bad and the test shows it borderline then replace it. I am in the same boat and soon as I can it is going to go away.
Massey
Massey
I am new in this forum. I have some questions about this forum. These questions are shown below
https://camaroforums.com/forum/70-81...working-86524/
If anyone has information about my question. Please give me answer below. I am very confused about this
:https://camaroforums.com/forum/70-81...working-86524/
What are you doing? You are posting in the 4th gen area bringing up a 11 year old post and asking about a unrelated question on a 2nd gen forum and this is not the first time you did it? If this some new kind of spam. Why would you not just post in the post your are asking about?
libertyforall1776
Feb 24, 2014 02:11 PM
