need to know if it will fit
Old Jul 3, 2007 | 03:31 PM
ninjamonkey's Avatar
Default need to know if it will fit
ok i have a 2000 3.8 v6 camaro and i am replacing the engine just need to know if the same engine out of a frontdrive buick will mount up into the car???? any info is helpful on this and also im pretty sure you cant but is it possible to fit the supercharged version in the car???? if anyone here could help me out with this asap i would be very appreciative thank you
Old Jul 3, 2007 | 03:38 PM
bluovlh8er's Avatar
Default RE: need to know if it will fit
yes if you gut everything out of the car and just have the shell. welding and stuff it is possible.
Old Jul 3, 2007 | 03:44 PM
ok umm well no i have a whole car the motor is dead not tryin to do custom work so then the supercharger wont fit but will just an na front drive one mount up ????
Old Jul 3, 2007 | 03:45 PM
The front drive engines do not have provisions to attach motor mounts on the side of the engine.
Old Jul 3, 2007 | 03:49 PM
SSV6's Avatar
nothing bolts up properly, the transmission won't fit, andthe harmonic balancer will point in the wrong direction.
