AC Compressor Sounds Funny
Old Jun 29, 2007 | 12:19 PM
xbdogs88's Avatar
Default AC Compressor Sounds Funny
My AC compressor cycleson for 2 seconds then off for 2 seconds. I checked the pressure on the low side and it is within normal range but the air from the vents is NOT cold...cool at best. Any suggestions.
Old Jun 29, 2007 | 12:33 PM
nsbjim's Avatar
Default RE: AC Compressor Sounds Funny
Iwould check the freon level, mine was doing that to, bought a can from advance for 8 bucks and she was blowing cold in no time.
Old Jun 30, 2007 | 11:07 PM
usarmyrangrs's Avatar
Something's causing the compressor to cycle. Have the system recovered and recharged, or try adding a can yourself. If possible, give me a high side reading along with a low side, in PSI.
Old Jul 3, 2007 | 08:12 PM
Conundrum's Avatar
Had the same problem with my Ram a while back. I have a buddy that works on cooling systems for houses and cars and he told me that whenever it kicks on and off like you're describing it's almost always due to low freon, or whatever the hell they're using now.
Rhapsk
Jul 6, 2012 09:09 AM
duane18
Apr 25, 2011 09:01 PM
badlandsusa
May 7, 2010 06:06 PM
bonedeth631
Mar 26, 2008 06:28 PM
