car sounds cammed
Old Apr 15, 2011 | 12:29 PM
duane18's Avatar
Default car sounds cammed
3.4L v6 5 speed. car sounds cammed at idle and has a really strong smell to the exhaust. replaced the map sensor,coolant temp sensor, and upper intake gaskets. (no vaccum leaks) and idea on what it could be would be great
Old Apr 15, 2011 | 12:41 PM
SloBalt's Avatar
NOOB
January 2012 ROTM
Technical User
Have you checked the intake piping? That may be what is causing the idle surge. I know you stated you replaced the intake gaskets but a recheck of all parts sealed correctly never hurts.
Old Apr 15, 2011 | 12:48 PM
duane18's Avatar
i sprayed everything down with throttle body cleaner and the idle stayed consistant. thats the only vaccum check i know how to do. and the intake is sealed up good
Old Apr 15, 2011 | 03:49 PM
mrfreez's Avatar
Could be your EGR. That will cause a similar issue.
Old Apr 15, 2011 | 04:49 PM
cscamaro's Avatar
those are good suggestions, but you should also check exhaust (headers/manifolds, pipes, and muffler for cracks or holes) mine sounds thae same way. Checked exhaust and found a couple of holes in pipes. Replacing pipes next week.
Old Apr 15, 2011 | 08:48 PM
nickb123's Avatar
My 98 3.8 did the same thing for about a month. I was just messing around I replaced the pcv and it made it idle perfectly smooth. An easy $3 fix.
Old Apr 18, 2011 | 11:57 PM
duane18's Avatar
is there a way to test the egr? cause i just looked it up and there 200 bucks. thats money i dont really have right now...
Old Apr 19, 2011 | 07:30 AM
drewscamaro's Avatar
just take it out and give the wires power and ground you should hear and see the valves open. I had egrs get alot of carbon on them and the wont open anymore so I cleaned it and started working again.
Old Apr 19, 2011 | 07:36 AM
Mr.Nicko's Avatar
well now i could be completly off but my bud had a 240 ya i no complete diff cars but wen his injecters went bad it ran real ruff and the idle was juz garbage vibrated alot sounded like it wanted to juz die took em and got them clean and it was fine
Old Apr 21, 2011 | 06:26 PM
duane18's Avatar
ok how exactly do i do this? i took the egr apart today and cleaned the ports and everything. the bottom of the egr where it bolts up to the headers was black with deposit and the inner ports had a red carbon on them. i cleaned everything out and put it back on the car. havent tried to start it yet but im sure it wont change anything. as for the wiring do i hook them up to a battery and start putting them in the prongs?
