need info on 350 carbarated
Old Jun 8, 2009 | 12:35 AM
mikemnbvcxz's Avatar
Default need info on 350 carbarated
will a carbarated 350 fit in my 94 camaro with out serious modifaction and if any one has done it a pic would be cool im wondering if it will drop right in but im not sure im thinking of taking a powertrain from an 85 and puting it in my slow poke 94 v6 car what ya think??????????
Old Jun 8, 2009 | 01:54 PM
95slvrZ28's Avatar
Not without some modification to the cowl. The problem really isn't fitting the carb under the hood, that can be done with a low rise intake assembly. You will however have to modify the cowl that the engine sits 1/2 under because of the distributor. 4th Gen V8's have the distributor on the front of the motor unlike the older cars which have it on the back side. You're also going to have to get a new K member to mount the motor. Needless to say it isn't just a "drop it in there" sort of job.
Old Jun 9, 2009 | 11:09 AM
ya im not to worried about the cowl im just wondering is the shifter going to fit and what can i do with the powerstering pump i may need to use an older one im gussing i would imagin that the older moter mounts would fit.any more suggestions are welcome
Old Jun 9, 2009 | 11:40 PM
lt4weeda's Avatar
anything is possible as long you are willing to put the time into it.
RodneysPhoto
Mar 28, 2011 01:44 PM
camarogurl843
82-92 V6 Tech
Nov 4, 2010 02:44 PM
Skidoo03
Oct 18, 2010 06:39 PM
Homestar1217
Jun 27, 2009 08:37 PM
vinnyboombots
Apr 4, 2009 03:14 AM
