Need help with tires
Hello i currently have purcahsed a set of wheels 17x9 with a 6.00 backspacing but the wheels suck out past the car to far in the front so i am sending those back and i was wondering if i get a corvette c6-zo6 wheels that are 17x8.5 i do not have the backspacing if you do please inform me but any ways will i have the same problem of them being to wide or or shold they fit well thanks
Andrew
Andrew
You didn't say what you are putting them on so here is generally what I found when I changed wheels on my 02 Z28. I looked at so many different wheels and no one could tell me if they would fit even when I had the offset numbers. I went to www.oewheelsllc.com in Florida and they have a large selection of wheels and will tell you if they will fit. I went the ZO 6 17x8.5 and they fit and look great. If you have lowered the car it will make a difference. Good luck You will really make the car stand out with aftermarket wheels..
