Need Help! Floor Drain Plug!
have you washed the car? that will go through the seals as well. get someone to run the water over areas of the car to see where it leaks, t tops, door window and door seals, rear hatch seals.
As reported above, the auto parts store test may not indicate a problem with "flickering" output from the alternator. They just check to see if the output current is above a minimum value, not that it is stable. You may have to just take a chance on a new one even if it passes the test.
The tester I have at my store is capable of detecting the diode ripple, voltage and output current. Those 3 items are what is needed to determine the health of the alternator. Flickering lights is a sign of bad or weak diodes. It also takes a person who knows how to read the test information to determine the overall health of the device being tested. Any idiot can hook up a tester and read the screen but a real tech knows what he/she is reading and advises the customer based on that.
Massey
Massey
BasicConcepts
12
02-27-2012 01:10 AM
