anyone got a drain plug in there 4L60E?
Old Jan 16, 2012 | 01:10 PM
BasicConcepts's Avatar
Technical User
Default anyone got a drain plug in there 4L60E?
where at?
Old Jan 16, 2012 | 03:47 PM
Grandpaswagon's Avatar
Nope, and I have the 4L60E in my Camaro and S10. Neither has a drain plug. The 4L80E in my fullsize doesn't have one either.
But the tranny in my Jeep has a drain plug. Go figure.
I am going to add one to my Camaro and S10 when I change the fluid and filter on them.
Old Jan 16, 2012 | 03:48 PM
torque_is_good's Avatar
Good idea
all of my Japanese vehicles have them (the auto tranny ones)
Old Jan 16, 2012 | 06:02 PM
MKCoconuts's Avatar
Are you talking a drain plug for the TC or the pan itself?
Most Chevy's save older ones don't have one for the TC.
Old Jan 16, 2012 | 06:39 PM
Technical User
i was more asking if anyone has installed one i knew they didnt come with it... anyways i bought one and installed it today just under the electrical but a little more towards the back (to clear the filter)
Old Jan 17, 2012 | 12:11 PM
MKCoconuts's Avatar
Awe, I see.
You know, you'd think they'd just come with one you know? Would make changing the filter much less messy.
Old Jan 17, 2012 | 12:36 PM
There's a trick to dropping the pan without "dropping" the pan and making a mess, don't remove all the bolts at once! The philosophy behind not installing a factory drain plug (in addition to cost savings) is probably so that the pan has to get dropped, then you're going to change the filter too. A filter is something that would probably rarely get changed if you could do it the easy way with only a drain plug.
Old Jan 18, 2012 | 08:28 AM
but some lazy (or perhaps creative) people with drain plugs install an in-line filter in the cooling line.
I'm not tossing out any names................ ;-)
Old Jan 18, 2012 | 09:32 AM
i have a drain plug in the trans, aluminum pan with coolin fins
Old Jan 19, 2012 | 08:38 PM
yellow2's Avatar
mine had a drain plug with the aluminum pan /w fins too but I see the 60's w/o plugs all the time.
