Need help finding these gaskets
So I'm going shopping tomorrow (this is like my almost-ultimate kind of shopping trip) for majority of my parts for the rebuild. I've been looking back and forth between the Advance Auto, Autozone, and Summit's websites trying to find the front main seal. I found the rear main, but I'm wondering if it's called something else? Also the front cover (the aluminum piece the water pump is bolted to)? Some of these things I just don't know what they are or what they also could be referred to and I can't seem to find anything between those sites. I want to make sure though too there isn't a gasket for the oil pump and no heater hose o-rings. I couldn't find any.
I took the heater hose orings to NAPA and they had some that was almost the same size. I bought them and they worked perfect. Not sure about the other gaskets.
Here is a link to what I think you are asking for
http://shop.advanceautoparts.com/web...0_964235877___
Yeah I saw that set, I recognized the water pump gasket...but I wasn't sure what the rest of those were...going back and forth between like 4 sites gets really confusing.
The larger gasket goes around the timing cover that the water pump mounts to. The smaller one is for the oil filter housing. Not sure what the smaller one on the right of the pic is for unless it is for EGR pipe that goes into the UIM. There is no oil pump gasket other than the one for the front timing cover.
Ah k. I tried looking up that part number to see if I could find an actual listing of what was included, but I kinda gave up after not finding it after clicking on a couple links.
What about this? http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_Conversion-Gasket-Set-Felpro_15180050-P_91_R|GRPGASKAMS_966001113___
The oil pan gasket I need separately is $44...this seems cheaper and it all works together.
That one looks like it has just about everything in it.
