need help
Old Dec 15, 2010 | 11:10 AM
Z2895's Avatar
Default need help
Im a noob I just got a 94 z28 and I have a red arrow pointing down at wavy lines and wondering what that means
Old Dec 15, 2010 | 11:31 AM
mab6680's Avatar
low coolent light check the coolent level if not then the sensor or wiring for the sensor
Old Dec 15, 2010 | 12:04 PM
Z2895's Avatar
thank you ima check and let you know what happens
Old Dec 15, 2010 | 06:52 PM
check coolant level in the radiator. the reservoir can be at the proper level and the radiator can be low. if the radiator is full then your sensor is bad.
