"My car hates me" saga continues--more trans issues
on my way back to WI from Dearborn yesterday, I got caught in 2 hours of stop-and-go traffic. After I finally got out of it, my car decided it no longer wanted to downshift on moderate tip-in. For the rest of the ride, it took a LOT more throttle input to actually trigger a downshift than it did before. It also usually used to downshift when I was accelerating with cruise control, but after I got through Chicago it didn't do that anymore. This transmission just got rebuilt last summer. Any idea what the heck is going on?
I did, just last summer (not even a year ago). It's not a heat issue, I drove the car yesterday after sitting for a couple of days and it had the same problem. I'll check the ATF today
then, since you are OBD2, get it scanned to see if you have an over temp code for the tranny
there are a few sensors used to decide when to shift or down shift. tps, maf/map, speed sensor, crank/cam sesor. have you gotten under the car to make sure there are no lose or damaged wires to the trany?
so I took the car to the shop that did the rebuild. No fluid issues, no codes. The guy said he "couldn't replicate the problem," which is BS because if he had driven the car before and after it started acting up, it would be a night and day difference. Also, idk if I mentioned this before, but sometimes in stop-and-go traffic when I actually start building some speed, the car sort of "hiccups," like it decides to downshift and suddenly says "just kidding." Something the trans guy said is it may be the throttle position sensor. That will have to be the next thing I check out.
Doubt it's the TPS unless an intermittant issue before failure. I had the TPS code on my SS when my TPS failed -- was one of the first problems I had with that car... Anyhow, the TPS is cheap, and a couple screws -- easy to swap.
tonyfronce
07-10-2012 10:33 AM
