Motor swap 3.4 to 3800
Old Jul 13, 2007 | 11:54 PM
burton9055's Avatar
Default Motor swap 3.4 to 3800
Hey I have a 1995 3.4, i want to swap to a 3800, i heard that u can just upgrade parts on the L32. If possible is it better to upgrade parts or get a 3800. And which is cheaper?
Thanks David
Old Jul 14, 2007 | 11:03 AM
Default RE: Motor swap 3.4 to 3800
Put in a LT1, less work & much better results. An extra 400 CCs is not worth the trouble.
Old Jul 14, 2007 | 02:39 PM
burton9055's Avatar
its a stick, rear drive, and i heard that u have to change a lot of things to get the motor and tranning to meet right, and how much is a good LT1
Old Jul 14, 2007 | 02:45 PM
V1cinity's Avatar
If you have the time and nothing to do...go ahead and do what Pete said. Best way is to find a wrecked LT1 Camaro and swap all the stuff over.
The easiest and best way to upgrade is...
Sell you're V6 and buy the V8.
Hope this helps!
Old Jul 16, 2007 | 03:52 PM
Danscamaro02SS's Avatar
or at lease put a 4.3L V6 in it if you want to sick with the 6ers
Old Jul 18, 2007 | 07:36 AM
squisher's Avatar
ORIGINAL: Danscamaro02SS
3.8 seems to be a bit better on the performance end, although the 4.3s have LOTS of low-end grunt. 3800 for V6 win, but with all the work of an engine swap, just do a V8.
How many miles on your current 3.4? If you do end up swapping out, I might be interested in your old motor (goes good in Fieros )
You say you heard that you can just "upgrade parts on the L32" Does that mean you heard that you can convert the 3.4 block to a 3800? I hope not, the 3.4 and 3800 are totally different engine architectures. 3.4 is a 60 degree v6, and the 3800 is a 90 degree v6. However, the 3800 does have decent power potential if you start upgrading *its* parts. Not as much potential as a V8, but it will net you better gas mileage (than even the 3.4 for that matter).
Synapse75
Oct 1, 2015 11:38 AM
PatrickM
Apr 7, 2013 12:18 PM
CamaroCam
Jun 26, 2011 08:17 PM
cschues80
Sep 5, 2010 03:14 PM
beer4me
Mar 4, 2010 05:22 AM
