Moaning noise from Rear End
Old Sep 7, 2012 | 09:45 AM
REN's Avatar
REN
Default Moaning noise from Rear End
Recently I have noticed a whining/moaning noise from the rear end. not a grinding noise somewhat high pitch moaning. Hard to describe. Usually heard when going slow and around corner only like in a parking lot. Do not hear it going straight though. Rear shocks are new and diff oil was replaced about a year ago (<5000miles). One piece driveshaft also new.
Gonna take a longer look this weekend but not sure what all to look for any ideas? Maybe something simple like sway bar bushings or could it be something bigger like the wheel bearings?
Old Sep 7, 2012 | 12:52 PM
MKCoconuts's Avatar
Sounds like something to do with the LSD since that is normally being worked while going around a turn or from a hard launch. I hate to say this, but I'd pull the cover and take a looksy. And now that I think about it, when you did the fluid change, did you remember to add a LSD additive? Or are you running a V6?
Old Sep 7, 2012 | 07:50 PM
REN's Avatar
REN
V6 no LSD
Old Sep 8, 2012 | 08:38 AM
Edwardgp's Avatar
Let us know what you see when you get the cover off.
Old Sep 8, 2012 | 10:00 AM
sounds like a bearing is starting to complain. is oil level low
Old Sep 8, 2012 | 10:30 AM
androzer's Avatar
The same thing happened with me last year and no one answerd me I thought first it was from the steering pump! and it happened only in hot weather or after driving for around an hour. this symptom apperad after changing the Differential oil. but this summer I didnt fell any thing or hear any thing!
the sound like: dink grighhh with kind of vibration.
Old Sep 10, 2012 | 02:36 PM
androzer's Avatar
what did u find?
Old Sep 10, 2012 | 07:26 PM
libertyforall1776's Avatar
You need new bearings in your diff -- had to do this on both my Camaros -- same symptoms.
However, since you don't notice this going straight, you may have some wheel bearing issues as well -- you need to locate the sound -- stick a passenger back there with a good ear!
Old Sep 19, 2012 | 10:22 AM
androzer's Avatar
REN tell us what did u find?
Old Sep 19, 2012 | 11:17 AM
March Hare's Avatar
If your V6 has the Y87 package it will have a LSD and needs the addative.
Just a thought
