misfire
Old May 4, 2015 | 06:39 PM
tarheel's Avatar
Default misfire
I have a 98 Z28 and have recently changed the plugs and plug wires. I now have a misfire. Put it on a code reader and it said it was #7 that was the misfire. I changed the plug wire and still had it. I then changed the ignition coil pack and still have it. Any ideas what it could be? It doesn't do it when the car is first started. It only does it after the car has been running for a couple of minutes.
Old May 4, 2015 | 07:54 PM
try a new plug. sometimes all you have to do is drop them and toast. what plugs you using?
Old May 4, 2015 | 07:55 PM
also double triple check your plug wire order to make sure they go to the right cylinders.
Old May 4, 2015 | 09:12 PM
tarheel's Avatar
Im using AC Delco Rapidfire plugs
samkopyna
Sep 5, 2012 10:41 AM
leonard1
Oct 23, 2011 10:41 AM
steveh3500
Feb 18, 2010 01:56 PM
dumbnstupidone
Jan 21, 2008 08:40 PM
NasteeZ
Oct 31, 2007 09:55 AM
