May have a little problem after intake manifold install
Old 12-09-2011, 07:43 PM
JGuy07's Avatar
The RTV goes around the front and rear of the manifold, so not creating a good enough bead with the sealant may cause a leak. Especially as I also mentioned if you didn't position the manifold correctly and somehow slid it around slightly as you were placing it. When using RTV on the rear and front you can go up the gasket a 1/4 of an inch or so to ensure a good seal. When you placed the manifold down, if sliding it at all you could've moved the gaskets or smeared the sealant. I had a manifold leak where it was contributing to my idle issues with constant revs and such. Fixed the manifold and it went away. You WILL have to do it all over again if you messed up, yes removing the manifold again.
Old 12-09-2011, 09:04 PM
Originally Posted by old guy
Did you try the old ether starting fluid check? Spray a little around all hoses and connectors, gasket areas too. If rpm picks up you've found the leak.
I know a lot of guy that use to do this and I never understood why they used stuff that was so dangerous. Use a can a carburator cleaner and spray it around heck even WD 40 will work. Listen closely for a change in RPM. Motor will speed up a as you get closer to the leak. I'll bet even gunk engine cleaner would work. Look for leaks and clean the motor at the same time
Old 12-09-2011, 10:33 PM
Yes, that could cause an oil leak, but we were talking about looking for a vacuum leak. A vacuum leak would originate from between the manifold and heads.
Old 12-09-2011, 10:56 PM
JGuy07's Avatar
Which is why I also mentioned in the first post that he may have slid the manifold while installing and could've moved the gaskets.
Old 12-09-2011, 11:10 PM
If the gaskets slid, he wouldn't have gotten the intake bolts in. When the holes line up, so do the ports.
Old 12-09-2011, 11:28 PM
JGuy07's Avatar
Good point
Could there be a chance the manifold or heads are warped? If they somehow came to that, the mating surfaces would be off. Different scenario I know, but a good question.
Old 12-09-2011, 11:35 PM
Good point
That's a good thought, crossed my mind too. Another one that did is, have the heads ever been milled down? If you go beyond a certain point, you want to have the intake manifold angle matched (shaved) to match up with the heads again.
Old 12-10-2011, 02:56 PM
bill2129's Avatar
Well guys. It looks like it may be fixed. When I was sleeping this morning my dad was nice enough to go outside and mess with it. He said the lid was a little off and the filter inside all bent up. He said he fixed that and it stopped. Hopefully that's what it was.
Old 12-10-2011, 03:04 PM
iLL95's Avatar
I Like to Party
Super Member
Glad to hear the good news, bet it felt nice waking up to some good news
  #20
Old 12-10-2011, 04:02 PM
bill2129's Avatar
It felt very nice. I was getting up to get ready for work to. So it made me feel a little better. I hope that was the problem. If not I shall be back
Quick Reply: May have a little problem after intake manifold install
