Max rear tire size?
http://www.hawksthirdgenparts.com/ca...opnewgm-1.aspx
the spacers wont help much, they mean your car rides the bumpstops, i think you looked into the problem too much, the camaro base model or whatever is same body shell as Z28, no changes, axle is same etc etc. So z28 rims and there stock tire size 245/50/16 will fit straight on no rubbing. I suggest not to put the spacers in as the car will ride bump stops over harse bumps and become unstable
Here it is the Carbon Z1 Vette
http://www.motortrend.com/roadtests/...est/index.html
bobbyvanmc
streetdreams.org
bobbyvanmc
streetdreams.org
alrright reall quick answer the first number in a tire size (245) is the width of the tire at the widest point so some 245/50/16s are wider than others depending on the brand the second number (50) is a ratio of the first that determines height so it would be 50 % of 245 and the third number (16) is the wheel size
