Tire size
Old Jul 7, 2011 | 03:58 PM
ZL1's Avatar
ZL1
Default Tire size
Will a 225R60/15 tire fit in a stock rear wheelwell without rubbing on a 69 Camaro with stock SS style wheels with 4.5" backspacing 8" wide and what size tire will fit the front without rubbing on a 15x7 wheel with 4.25 backspacing?
Thanks
David
PS I am new to the forum so be kind to me.
Old Jul 11, 2011 | 01:04 PM
StoveBolts's Avatar
Hi David,
You'll have lots and lots of room with that 225/60/15 on the rear.
I'm running a 255/60/15 on an 8" rim on the back and I have a comfortable amount or room to spare, even with the 2 inch drop I have in the springs. The 255's are a little taller than the 225's your looking at, but with a matching 215/65/15 on a 7" rim that I have on the front, I'm really appreciating not only the stance, but the clearance I've gained with the headers. Yeah, yippie I A ! No more bottoming out on the RR tracks from when I had the 195's up front.
Old Nov 4, 2011 | 11:52 AM
68hou's Avatar
David,
way late on the response. Have a stock height 68. I'm running 255/60-15 Mickey Thompson's on 8.5 inch rims with 4 3/4 backspacing on the rear and there is tons of room. I do have Competition Engineering drag links and Hotchkis rear antisways plus subframe connectors to keep things in their place..
Old Nov 4, 2011 | 02:42 PM
astontibs's Avatar
With that rim in the back you should be able to go as large as 255-60-15 with no problems. You may be able to get away with 275-60-15 depending on your height and the stiffness of your rear leaf springs. I believe a 215-65-15 would be perfect with your front wheel. I tried a 225-60-15 in the past, but I had rub issues on tight lock turns.
Old Nov 4, 2011 | 04:41 PM
JG69's Avatar
Hi Dave, I'm running 255-60-15's in the rear and 235-60-15's up front on my 69. There are lots of tire/wheel options for a 69 depending on what look you want. BTW...Welcome !!
Davila2000maroRS
Apr 27, 2011 05:13 PM
68SS/RS
Aug 22, 2010 05:28 PM
kstoll99
Sep 27, 2009 11:13 AM
bd92rs
Aug 7, 2009 09:04 PM
DUB C
Feb 11, 2008 07:03 PM
