Manual Fan
Make sure the relays you put in are good. I had the same problem with my fans, so I went and bought a new relay. Still didn't work. Turns out the brand new relay was bad. When I put the new replacement relay in, it worked fine. I also put the SLP fan control kit on mine. Pricey, but I like the clean easy install and it works great. Now no more slowly heating up in stop and go traffic in this hot NC summer.
Ok. I wired a manual fan switch. Before i mounted the switch I made sure everything worked. It did. Then after I mounted switch in position it doesn't work now. Could the switch have gone bad? I used a on/off/on switch. Ran a wire to the acc in fuse box to switch. Ran wire for highs and wire for lows. Any ideas??
Sounds like you need to run the fans directly off the battery with an inline fuse between the battery and switch ( hot side ). Use #10 ga wire and connectors with the fuse close to the battery. One set for each fan. 30 amp fuses, the acc is not big enough.
Checked wires at switch. Hot has power. Each wire to the fans has power. I took test light and stuck point in one of the wires from switch and fans came on. Once you remove tester fans shut off. I had it grounded to battery -. I am totally puzzled.
