Lt1 swap problom
Old Mar 3, 2016 | 10:56 AM
Juan97camaro's Avatar
Default Lt1 swap problom
97 camaro rs swapped lt1 from 97 Z28 finished wiring up connected the battery dash lights came on fuel pump primed automatically as soon as battery cables connected. Anyone can help tell me were the problom is?
Old Mar 3, 2016 | 12:23 PM
What systems did you swap besides the PCM? BCM? ABS? Dash? Did you get all your grounds hooked back up?
The 97-97 swap is the easiest 4th gen swap out there according to this web site.
http://www.tacreationsusa.com/3_4_3_8_v6_to_lt1.htm
Old Mar 4, 2016 | 04:49 PM
MKCoconuts's Avatar
The ignition wasn't in the run position while connecting the battery was it?
andyssw
Oct 18, 2021 07:17 AM
hoursetraitor
70-81 Transmission & Differential
Jan 10, 2011 04:02 AM
zdav28
Oct 31, 2009 05:36 PM
pimpjuicepd
Mar 24, 2009 09:48 PM
