lt1 DOHC SOHC?
Two cycle engines run fine, with no cams at all. LOL
But there are also some other weird combinations like the old GM X71 2 cycle diesels. No intake cam or valves, but a roller cam for the exhaust sidewith 4 exhaust valves per cylinder. Engine used a blower to pressurize the crankcase and intake air was let in through a window in the cylinder wall.
Rotaries suck and i stand by it... check this out:
2002 Mazda RX-7 Spirit R Type A
Horsepower: 280 @ 6500 rpms
Torque: 231 ft/lbs @ 5000 rpms
Weight: 3,400 lbs
Transmission: 5 spd. manual
Engine: 13B-REW Twin Rotary
I know its alot of hp for alil dorito powered rotary but it doesnt really have much on a LT1 camaro even and LS1s will walk em (thats why they drop LS1s into Rx7s..)
Weight: 3,400 lbs
![Name: 627_must5.jpg
Size: 78.2 KB](https://camaroforums.com/forum/attachments/93-02-general-41/43441d1501347393-lt1-dohc-sohc-627_must5.jpg)
wow, thanks. im well aware of that very popular swap after they blow up the rotary. my first car was a 84 rx7 that i put in a 383. did you know that if it wasnt for the oil crisis in the late 70's the corvette was going to be a mid engine 3 rotor?
matts88camaro
82-92 V6 Tech
18
06-29-2009 07:28 PM
matts88camaro
82-92 V6 Tech
06-20-2009 07:16 PM
