lt1 crankshift
Old Dec 16, 2007 | 01:46 PM
ctboy's Avatar
Default lt1 crankshift
next year i am rebuilding the motor with new piston heads and rocka with a new camshaft. but need to know if the crankshift is alright to use because i am puttin nos in the car!
Old Dec 16, 2007 | 02:09 PM
95camz28's Avatar
Banned
Default RE: lt1 crankshift
i wouldnt use the same crank i would buy a full rebuild kit from summit racing with all new pistons rods crank etc. i wouldnt trust the stock bottom end
Old Dec 16, 2007 | 05:48 PM
Chappie99's Avatar
ORIGINAL: 95camz28
Why? just check out the clearence of your bearings send it out and have it micropolished and it will be fine. You may need to put oversized rod and main bearings in if there is high mileage on the engine. There is no need to replace it. A crankshaft is one of the most dependable internals an engine has.
Old Dec 16, 2007 | 08:26 PM
ctboy's Avatar
ok, what are some good crankshft out their!! another word's top brand! and i am lil confuze but need to put this out. is the lt1 383 or 350? i think i got a 383 because all my friend are import owners then domestic!
Old Dec 17, 2007 | 12:23 PM
95slvrZ28's Avatar
You have a 350, but if you put in a new crank you could make it a 383.
Old Dec 17, 2007 | 04:32 PM
Chappie99's Avatar
ORIGINAL: 95slvrZ28
??????????. If you want to make a stroker, you would need a crank from a 400 CID. Dude, you dont need a new crank unlessyou spun a bearing and the journal is blue from excessive heat. Still, then you can just have it machined at a speed shop.
Old Dec 17, 2007 | 05:08 PM
kaoss_11's Avatar
just micropolish the one you have get it balanced and your good to go.
