LT 1 6spd take off rattle
Old Apr 6, 2008 | 04:01 PM
cow bay z 28's Avatar
Default LT 1 6spd take off rattle
I'm a newbie to the forum & to Camaros. I bought a '95 LT 1 6 spd Z 28 with 80K on. It has a rattle on take off in the bellhousing / trannie area. It only happens on take off in first gear, and goes away above 15mph. I was wondering if anyone else had encountered this problem. or any thoughts on it?
The car is in Florida, and I have found out that it runs hot 230+F in stop & go traffic, I realize the fan specs are 226 & 235F but this isn't reassuring when you're waiting for it to boil over ( it hasn't yet ! ) Should I be worried?, should I wire a manual switch for the fans ? Any suggestions ? Thanks Alan
Old Apr 6, 2008 | 04:14 PM
Big_Bird_1985's Avatar
Default RE: LT 1 6spd take off rattle
If it a 6 speed which I think it is. It most likely is 1st gear chatter. If it is a new or fairly new clutch it may do this for a while. Especially if it is a aftermarket performance clutch. Say a stage 3 or stage 4 clutch for example. If it is you have nothing to really worry about. Its OK. If you do have an auto it could be anything from a loose transmission mount, failing torque converter, to a bad synchro. Hope this helps.
On the running hot thing wiring a fan switch might help the problem but your cooling system could use a good flushing and probably a new thermostat.
Old Apr 6, 2008 | 04:29 PM
Yes it is a 6 spd, but the rattle is a metallic one, it sounds like it could be a trannie bearing but it goes away above 15mph, so it can't be. A trannie guy I know said it could be a loose spring in the clutch plate but who knows ? Thought someone else may have experienced the same rattle.
Re temp it runs fine on hwy @ 185F ........................... Thanks Alan
Old Apr 6, 2008 | 08:50 PM
importmd's Avatar
they all make that noise, its normal
VicsLs1
Sep 8, 2011 03:14 PM
robbygz28
Jul 5, 2011 10:50 AM
roman36
Mar 4, 2011 05:41 PM
tmas02
Jan 4, 2008 01:47 AM
badinfluenceRS
Jul 2, 2007 01:31 PM
