LS3 in a 93z
Old Feb 6, 2008 | 09:35 AM
Altekameraden's Avatar
Default LS3 in a 93z
I have a 93z28 a4 and I'm thinking about installing an LS3 in, and was wandering what anybody thought about it. I could use help in deciding what to do about the mounting, PCM, entire drivetrain, and anything else you guys think needs to change. thanks in advance
Old Feb 6, 2008 | 05:17 PM
95slvrZ28's Avatar
Default RE: LS3 in a 93z
If I were you I'd go for an LS1 or LS6, I believe the LS2/LS3 has different mounting points as well as taller heads so you may run into some clearance issues. The other thing that you have to consider is that you're going to have to get all the correct sensors etc. to get everything to run right. Good Luck!
Old Feb 6, 2008 | 11:03 PM
libertyforall1776's Avatar
Check out some details here:
http://en.wikipedia.org/wiki/GM_LS_engine
