LS1 brake swap onto 96 LT1
Like it says Im doing the LS brake swap on to my 96 Z28 and I wanted to double check which hub to use. I believe I saw somewhere that you have to run the LT hub because of a difference with the speed sensor plug on the LS hub. Can someone that has done the swap please confirm this for me.
This may help ya, I did the rear swap on my old '95 3.4L...
Drum to Disk Brake Swap (1993-1997) - FirebirdV6.com/CamaroV6.com Message Board
