Lower control arm bolt seized (stuck) (rear bushing)
Old 11-21-2011, 11:24 PM
chevcamaro's Avatar
Obviously.. I would skip step 1.. lol.. Any other tricks to this? how do i support the engine?
Old 11-25-2011, 02:58 PM
libertyforall1776's Avatar
^ Be sure you get a front end alignment after you do this job...
Old 11-25-2011, 03:40 PM
1augapfel's Avatar
Ug, BTDT.
I got *almost* as medieval as Socom on my 94 V6. You're right, the bolt fuses to the bushing's inner steel sleeve.
I used a 3" air powered cutoff wheel to grind off the bolt head and a big drill bit to then recess the bolt shank. After prying apart the subframe eas there I was able to sneak out the control arm.
Awful job. AWFUL
Old 11-25-2011, 06:32 PM
You need an air-impact wrench, failing that, it's cutoff wheel time...
sm515
04-20-2013 03:57 PM
chevcamaro
12-05-2011 12:06 PM
grover
12-04-2011 11:45 AM
chevcamaro
12-02-2011 01:03 AM
mycarsux88
01-19-2008 08:56 PM
Quick Reply: Lower control arm bolt seized (stuck) (rear bushing)
