Low beams turn off by themselves
Old Sep 17, 2009 | 05:59 AM
chewybacca11's Avatar
Default Low beams turn off by themselves
Just like in the title... the low beams on my headlights will just suddenly turn off. The high beams work just fine. Sometimes if I click the high/low switch a couple times they will work again. And it has nothing to do with bumps because they haver turned off when the engine is off and the car is sitting still. BTW its both sides that go off not just one.
Whats the problem friends?!
Old Sep 17, 2009 | 06:50 AM
Jim Rage's Avatar
Which model year? And do they do this at pitch black night time? or dusk? or cloudy day?
^JR^
Old Sep 17, 2009 | 03:52 PM
Oh good point... but they do this at all times. But definately pitch black night time. And I've also tested it during the day and it's the same thing. 2001
Old Sep 17, 2009 | 06:31 PM
Jim Rage's Avatar
I should have asked this in last post. Does it do it when your lights are left on auto? or when you turn that **** all the way over to ON?
^JR^
Old Sep 18, 2009 | 10:58 AM
Parrish's Avatar
sounds like a loose connection or bad wire. Check your fuses too.
Old Sep 26, 2009 | 06:29 PM
I don't remember if they work with the **** on I'll have to check again tonight thank you. And I'll recheck some fuses. Would there most likely be a problem in the fuse box in the door jam area or the box under the hood?
Old Sep 26, 2009 | 06:46 PM
lt4weeda's Avatar
my car did something similar it wouldn't let the highs stay on or they would turn off all the lights all together. come to find out the headlight switch wasn't connected to my steering column so when i went to turn it between highs and lows the switch just moved instead of moving the switch internals. could also be a faulty switch on the dash.
Old Sep 26, 2009 | 10:06 PM
used to be when a car did this it was the dimmer switch. now im not so sure.lol.
chevy916
Apr 17, 2011 07:08 PM
dane0789
Aug 30, 2010 03:56 PM
Skippysnax
Mar 19, 2010 06:46 PM
redstarz808
Feb 16, 2009 07:26 PM
91camaro305rs
Jul 24, 2006 04:46 AM
