LOSS OF POWER please help
Old Mar 23, 2012 | 02:00 PM
djordan's Avatar
Default LOSS OF POWER please help
I have a 1993 camaro with the 3.4 v6 5 speed it is a work in progress but i have an issue that i can't figure out while driving it sounds like it is sucking in a lot of air or maybe blowing it out on the passenger side of car and i have lost power due to this but while the car is sitting still and you pop the hood when you rev the motor to listin you cant hear this sucking noise
anyone have any ideas
Old Mar 23, 2012 | 03:31 PM
It's possible your cat converter is plugged/restricted, and it gets worse the hotter it gets (the more you drive). If that's the case, exhaust pressure will be getting out anywhere it can, like through the donut gasket, at the manifold gaskets, and any loose gaps or pipe fittings you may have. It may not be doing it in the driveway since the engine and exhaust system had time to cool down some.
Old Mar 23, 2012 | 03:39 PM
Pretty much what I was thinking about.
Old Mar 24, 2012 | 09:06 AM
djordan's Avatar
I was told that it could be the eve valve as well
Old Mar 24, 2012 | 10:46 AM
OK, what's an eve valve?
Old Mar 24, 2012 | 03:34 PM
Is that opposed to a morn. or aft. valve? Did you mean EGR valve?
Old Mar 25, 2012 | 10:32 AM
djordan's Avatar
Yes sorry trying to post from my phone
josh H.
Jun 21, 2015 12:06 PM
x01660
Mar 9, 2011 10:18 AM
80z28guy
70-81 V8 Tech
Jan 4, 2010 10:51 AM
LT1RUNNER
Dec 4, 2007 10:45 AM
gijoe985
Oct 13, 2006 11:58 PM
