loose convertible top
Old Sep 20, 2010 | 06:51 PM
bigtim1985's Avatar
Question loose convertible top
i know this is a camaro forum.....but please help anyway. i just bought a 2001 trans am ws6 convertible. the top is still in pretty good condition but is a little loose on top. i cant find any posts on this. as far as i can see you have to take apart the front by the windshield where it is glued pull it tighter.... and re-glue?? just want to see if there is and easier fix to snug up the top. thanks in advance
Old Sep 20, 2010 | 07:14 PM
traumadog's Avatar
Yes, you have to pull it at the header bow. There's a band with a bunch of little screws that hold the retaining band in place. Lift the top halfway, unscrew those little Phillips screws, then pull down about an inch or so and replace.
Here's the pic of when I installed my top. The yellow crayon mark was the original edge when left loose. Right below that is the band you have to remove to tighten the top - and since your top was in place already, I wouldn't tighten it too much.
http://www.flickr.com/photos/jchen004/3435061863/http://www.flickr.com/photos/jchen004/3435061863/ by http://www.flickr.com/people/jchen004/, on Flickr
Old Sep 20, 2010 | 09:45 PM
bigtim1985's Avatar
thanks alot......sounds like a fun project for this weekend.
Old Sep 20, 2010 | 10:50 PM
By loose, do you mean the fabric or the fit to the header?
Old Sep 21, 2010 | 07:01 PM
bigtim1985's Avatar
the fabric on top is almost sagging between the bows.
Old Sep 22, 2010 | 10:35 AM
greenarrow's Avatar
September 2009 ROTM
How much of the top is hanging over the back window? You may need to replace the whole top if it's not covering the top of the back window, or pull it tighter in the back.
Old Oct 8, 2010 | 03:41 PM
bigtim1985's Avatar
how do you tighten the top from the back? i dont have enough top hanging over the rear window to tighten the top from the front. thanks
Old Oct 8, 2010 | 04:08 PM
Chivas1's Avatar
my back window also came unglued from the top, took it to a window glass place & they told me to get some glue that would work for both the top & window, pull the top about 3/4 down to glue, let it dry for some 4 hours & it should work. gotta try it this weekend.
sorry dont mean to take over your thread but does anyone know what glue would be good for this?
hjistc
Dec 7, 2011 01:29 PM
3800camaro
Oct 19, 2011 07:25 AM
01camaro.dude09
Aug 29, 2011 11:54 AM
black95z28
Mar 9, 2010 11:05 PM
ScottD
Aug 11, 2008 12:37 PM
