Looks like an LT1 but i need a 2nd opinion
Old 03-08-2008, 11:04 PM
SpeedyWhop's Avatar
Default RE: Looks like an LT1 but i need a 2nd opinion
TANGENT: LT1 is also Reverse coolant flow, which is why you need a special T-stat for the LT1. The purpose of the reverse flow is to cool the heads down with the coolant right out of the radiator (the coolest coolant) this makes the LT1 produce a higher Compression ratio than a standard SBC.
BACK TO YOUR BLOCK:
GM also made an LT1 with CAST IRON heads (impala, caprice, roadmaster etc.)
As far as from the pics, it does not look like one b/c the timing cover would have acam drivefor the Optispark Distributor.
  #22
Old 03-09-2008, 02:09 PM
AV95Z's Avatar
Lt1's didnt have coolant crossover through the intake manifold... the one your showing does.
  #23
Old 03-10-2008, 05:30 PM
Spartan66's Avatar
how can you tell it has coolant cross over or w.e it doesnt have an intake manifold and its hella dirty..
Anyway heres what i got from the casting on the head:
14102193...87-up...305/350......1.94"/1.5" valves
(and it its the 350 bkuz it has GM 5.7L stamped on it)
  #24
Old 03-10-2008, 06:54 PM
95slvrZ28's Avatar
Well Spartan, as said multiple times before, it's not an LT1, sorry buddy. You could build a pretty mean SBC out of it, but you can't have the reverse cooling or anything that the LT1 has, which is going to limit your compression etc. I wouldn't buy it in hopes of putting it in your car, but you can still have some fun with it.
  #25
Old 03-10-2008, 07:53 PM
That is not an LT1. If you were to put it in your car, there are going to be clearance difficulties with the distributor, as it is going to wind up on top of the engine and under the windshield.
  #26
Old 03-11-2008, 03:02 AM
Spartan66's Avatar
damn... oh well ill just toy with it thanks for your help guys.
  #27
Old 03-14-2008, 09:49 AM
AV95Z's Avatar
ORIGINAL: Spartan66
see how on the intake side of the Lt1 heads there are only the 4 intake ports and the three coolant ports arent there like the one you were showing
  #28
Old 03-14-2008, 09:57 AM
Spartan66's Avatar
ah i c.
2000sscamaro
05-02-2011 01:23 PM
agentk349
08-11-2008 05:15 PM
camaroBabe
06-20-2006 06:54 PM
Quick Reply: Looks like an LT1 but i need a 2nd opinion
