Looking to strip down my 2000 Camaro SS LS1...
Old Aug 9, 2011 | 06:42 PM
Massey's Avatar
There is not any major improvement over true dual exhaust and a well built single setup. Before you all flame me re read what I said... WELL BUILT not just throw a pipe behind the cat and put on a good muff. Get better cats, and have the exhaust built from the headers back and you can achieve the same performance with 1/2 the pipes and also keep your car from scraping or rubbing the driveline. These cars are not really engineered for true duals but you can make a really nice sounding Z or SS with about a grand in the pipework under the car.
Massey
Old Aug 9, 2011 | 09:10 PM
inanitydefined's Avatar
Massey is right. In fact, in a properly sized exhaust system, true duals will make less power and a narrower torque curve than an x pipe or a single pipe. This is due to the same scavenging effect that makes equal length primary headers superior. You'll also save an easy 20 pounds of dead weight
Old Aug 9, 2011 | 09:33 PM
Failed Devices's Avatar
X pipes and H pipes also promote scavenging. A 2.5" true dual setup on an fbody will outflow a 3" y pipe one and will make more power.
Old Aug 9, 2011 | 09:59 PM
Edit: I apologize, I thought I saw 2 inch, not 2.5. You're right, 2 2.5 inch pipes create a flow area of 9.7 inē. One 3 inch pipe will create a flow area of 7.06 inē. However, one 3.5 inch pipe has a flow area of 9.6 inē, a negligible difference from 2x2.5 with significant weight savings
Two schools of thought. I'll concede that true duals sound nicer in some situations. To me its not worth the weight, when a single pipe can have 95% of the tone depth
I also mentioned an x pipe. Leave h pipes to the silly fords
Last edited by inanitydefined; Aug 9, 2011 at 10:15 PM. Reason: reread FDs post, cleaned up for easier reading
coopdc78
LS Series Tech
Jun 19, 2010 12:28 PM
camaro2360
Feb 4, 2010 01:12 PM
Mx35foxracing
VS
19
Dec 3, 2007 10:19 PM
chevy_man
Jun 25, 2007 08:56 PM
