Lifter
not hard. have to take the intake maifold off and valve cover to get to the rocker assembly. need to identify the failing lifter first unless your changing them all. take the rocker off and remove the push rod then u can pull the lifter. are u sure its a failing lifter and not a miss adjusted lifter? another thing u need to look at first is oil pressure. if u have low pressure at ldle when warmed up the issue will either stay or come back.
