Leaking turn signal lamp
Hello all,
I just bought a 1999 Camaro V6 base. The passenger side front turn signal lamp was broken so I replaced both with aftermarket. I found that the rubber washer that goes between the lamp and the socket is missing. This is allowing water to collect in the lamp. I called a dealer and they said they have to sell the washer with the socket assembly. 81.00. No thanks. You guys know where I could get a replacement? I tried Lowes and parts stores but no luck.
Thanks!
Thanks!
I went this route of trying to keep the water out of my DRL housings for years. New gaskets, new sockets, nothing helped. Then I finally did a leak test on the housings and found that there were tiny separations in the sections of the lens (not cracks, just gaps in the seams. I coated both lens with clear epoxy. No water intrusion in over a year, and I live in Florida.
