leaking ttops
leaking ttops
My ttops are just beginning to leak. I got some sealant from the part store and that helped, but I'm still getting little drips. I don't want to take it to a dealer and have them replace all the gaskets unless I have to. ($$) I heard you could get into your ttops and adjust them to fit better. Is this true? If it helps I can see the steel pins on either end which hold the ttops in place. The leak is right were these pins are in the crack between the cars plastic and the ttops plastic.
Thanks
Thanks
RE: leaking ttops
When my old camaro..95 v6.......was leakin it turned out to be the window! I took off my door panel and my bolts that hold the window motor were all off exept for one! They cracked though the fibergl*******s somehowI bolted them back up with washers and it allowed my window to go up 3/16 of an inch wich sealed it! Might try it??
Melssj5
08-06-2011 03:41 PM
