larger throttle body
Old May 11, 2008 | 04:13 PM
SpecterGT260's Avatar
Ninja Administrator
Default RE: larger throttle body
on a stock engine its not going to do much of anything. you need to go after the part of your engine that is the most restrictive. either the intake or exhaust on stock engines
Old May 21, 2008 | 04:17 PM
TEXASMAN1's Avatar
so if i have an intake it will help then or you need like full boltons?
Old May 21, 2008 | 04:28 PM
Ninja Administrator
at lest full boltons first, and then a nice sized cam. THEN start thinking about a TB
Old May 23, 2008 | 12:28 AM
95slvrZ28's Avatar
Like I previously stated, a 58mm TB isn't going to get you anything unless you're running around 350+ RWHP. A 52mm TB is probably a good thought if you're running a more mild setup that's getting you around 310-325 RWHP.
B_Dubya
Sep 23, 2014 11:01 AM
DDRDiesel
Jul 6, 2012 02:52 PM
black95z28
Jun 8, 2009 02:13 PM
CamaroKid16
Nov 5, 2007 08:26 PM
Skip94z28
82-92 V8 Tech
Nov 21, 2006 03:47 PM
