key wont turn in drivers side door
Old Jan 19, 2010 | 12:44 PM
tipdrip215's Avatar
Originally Posted by craby
has the lock been messed up from the before u got the car or did it start recently? if so was there work on the widow or window motor or the door in any way. linkage from lock to key mechanism could be jammed.
i had a window motor replaced, but i think it was after the lock already got like that.
Old Jan 19, 2010 | 04:13 PM
take the door cover off and have a look see. could be as simple as reconnecting or unjaming the arm.
Old Jan 19, 2010 | 05:01 PM
So....lubing up all the mechanisms with penetrating oil didn't help any?
Old Jan 20, 2010 | 07:24 PM
tipdrip215's Avatar
well i just got my car back from the shop a few hours ago, the old 3.8 had a leaking rear main seal, and leaking oil pan and valve cover gaskets. when i got home i tried hitting it with WD40 from every angle but the key still doesnt turn. tomorrow ill probably pick up some PB blaster or graphite and see if that frees it up. then if that doesnt work ill start taking apart the door and what not.
Old Jan 29, 2010 | 03:30 PM
tipdrip215's Avatar
ok after being busy for about the last week, i finally took my door apart and hit the lock with PB blaster, graphite, and penetrating oil, none of that worked, what needs to be replaced?
Old Jan 29, 2010 | 03:45 PM
From inside the door, can you see the lever on the lock mechanism (the part you stick the key in) move at all? You need to know if it's the lock or the door mechanism that is frozen. The lock is an alloy and the tumblers are brass. It's not uncommon for those two to get corroded and fuse together. If the tumblers don't slide, the lock ain't turning. Did you shoot PB into the key slot? If the thing is frozen stiff, you'll need to remove it from the door and work at it. I've gotten them free before, usually with some heat from a torch and tapping on it. It's impossible to do that while it's still on the door. Just be careful because the body is pot metal and it can melt easily with the torch.
Old Feb 28, 2010 | 11:34 PM
noah3210's Avatar
I got the same problem with my driver side door and my trunk I can actually turn the keyhole 360 degrees or at least the plastic around the keyhole
Old Feb 28, 2010 | 11:43 PM
its either broken or came lose. gonna have the take the door panel off and have a look to know more.
Old Mar 1, 2010 | 08:50 AM
noah3210's Avatar
well i bought a keyless entry kit will it still open the door if I install it?
Luckey95
Jul 18, 2011 09:00 AM
trigger987
Aug 30, 2010 02:26 PM
1986CamaroZ28
Jul 13, 2010 06:02 PM
reaper2702
Sep 5, 2009 11:42 PM
usafwilson
Jun 21, 2008 06:57 AM
