just changed waterpump, rpms are high now??
hey all, just swapped out the original pump with an airtex one, inorder to get it out i took off the 3 10mm bolts on the throttle body and set it aside in order to get the pump off, however now the car idles at about 1500-1900 rpm i park and neutral, whatd i do wrong?
Also does anyone have experience with falken tires or even falken tires one 4th gens?
make sure the plugins for all sensors around the pump are all plugged in right. could try the old spraying carb cleaner where you think the leak might be to see if it changes the idle trick.
