Intermittent Trouble Starting
Old 08-30-2012, 07:52 AM
TJeep_1999's Avatar
Originally Posted by Gorn
If you have spark and fuel pressure next your going to get a fuel injector noid light to verify the injectors are firing.
Just curious, would an issue with the injectors also keeping it from running correctly once it got started?
Thanks for all the input! Thought I would post here with an update. Computer system is free of trouble codes. Fuel pressure gauge indicates pressure is good. Replaced the fuel pump relay, but the problem still persists. My next move is to replace the plugs/wires. Will post more updates when I have them... Thanks again!
Old 08-30-2012, 09:12 AM
woh,,, no codes. that makes it a little harder to find the gremlin. quality plugs and plug wires would be a good start. a failing injector can cause issue that comes and goes but is unusual. test the evap system to make sure its not hiding there.
jshblue8907
07-22-2014 07:01 PM
Ceri@thecornwalls.com
01-16-2013 04:13 PM
jmeade65
10-06-2010 11:16 AM
troy5118
07-09-2009 03:23 PM
Kayla
02-25-2008 05:26 PM
Quick Reply: Intermittent Trouble Starting
