intermittent radio failure
Old 08-29-2008 | 03:49 PM
casjr's Avatar
Default intermittent radio failure
The radio in my 98 convertible goes out intermittently. This usually occurs after hitting a bump. I can go days without a problem. Other days it quits every 30 seconds. When this happens, the power windows and power top also quit.The windows, radio and top are on different fuses. Could this be a short in the radio?
Thanks in advance for your help.
Old 08-29-2008 | 07:52 PM
Default RE: intermittent radio failure
The BCM (Body Control Module) controls all the stuff that is losing power. Check the BCM and all the wires and connector attached to it, most likely loose and reacting to the bumps.
92elder
05-28-2011 10:05 AM
Chaotic94
07-05-2010 10:25 AM
Jburd964
02-07-2010 07:30 AM
deadbird
07-23-2009 12:43 PM
randscr
09-08-2006 10:48 AM
Quick Reply: intermittent radio failure
