intermittent miss
Hey there i have a 93 z28 6 speed and i just replaced my intake manifold and got it running again then like 2 weeks later my car has been acting up im getting a bad miss firing going on. i replaced my tps censer and some one told me the my temp censer might have gone bad but i cant figure it out do you think it might b my vacuum line from when i replaced the intake manifold or what would you think it might be?
You should start your own thread especially since the answer to the original post will not fix your car (there 2 completely different cars) anyways did you program the tps correctly?
the weird thing is the first time i start it it runs fin but then if i turn it off and go in side and come out later to go to the store it sounds like its running off 4 cylinders and found some of the wires were starting to krode
